How does the micro sd card have to be?
It can be a 256gb card
Hi, I am using a 400GB in a HeroBook Pro and I have seen others use 512GB in other Chuwi laptops.
I am using a 512GB micro sd card in Hi10 X, it has been working great.
Hey there.
I’m using SanDisk extreme 1TB micro SD card on Hi10 X (N4120). i have no issues so far unless you format as NTFS.
(But i don’t recommend buying it because it’s slow as hell. Well i have this card in the first place because i have a broken Nintendo Switch🤦)
Thank you very much Godzilla
What brand and model is the microsd card.
Hi modest
I am using a Micro Center brand micro sd card.
Micro Center 512GB microSDXC Class 10 / U3 / V30 / A1 Flash Memory Card with Adapter
https://www.microcenter.com/product/626488/micro-center-512gb-microsdxc-class-10-u3-v30-a1-flash-memory-card-with-adapter
I have a Microsoft Office 2016 suite installed on Hi10 X, and the Outlook .psd file is located on this micro sd card.
It is not slow, it is just working fine.
I organize my multiple .psd files like 2018, 2019, 2020, 2021, so each year is just about 3GB.
And all these .psd files open without any delay or hiccups.
I hope this helps on your decision-making process.
Thank you very much for the information
