CoreBook X 7430U transparent keycaps
Hello to the Forum
I really do like the X 7430U and expecially its keybaord layout.
Unfortunatelly I really need localized keyboard for my work and using stickers is not a good solution when working at night with backlit keyboard.
Does anybody know a source for totally transparent keycaps compatible with CoreBook X 7430U keyboard that I can customize?
Thank you for redaing
Raf
Hello
You can buy a wired or wireless keyboard that has the configuration you need.
Having an extra keyboard when I’m on the move is not an option for me.
I have seen that after-market transparent keycaps exist for some laptop brands, but nothing declared compatible with Chuwi
There are some insoles that are placed on top of the keyboard, which are made of silicone or a similar material.
The problem might be finding a compatible one.
Finding custom keycaps without designing and 3D printing them yourself could be very difficult. I recommend setting the keyboard layout to your locale and hope that you can touch type. My Minibook X has a Japanese keyboard layout because I got it in Japan, but I set the layout to US and touch type. It works fine. I mistype quotes sometimes as the quote key is weirdly narrow.
