Corebook X i3-1220P RAM settings
I need to advanced bios settings to correctly adjust the ram frequency and enable the xmp profile
Hi
You can look for a tutorial on Google or YouTube.
On most laptops in this class the BIOS has no XMP or RAM timing controls, and the memory is often soldered, so there may be nothing to adjust. Before hunting for hidden advanced menus, check the service manual or spec sheet for whether the RAM is removable and XMP-capable. If the BIOS lacks those options, I would not flash a modded BIOS just for XMP; the risk outweighs the gain.
the ram is removable ..i have changed it to 16gigs x 2 ram sticks
