I cloned the OS and put in on a 1tb m.2 drive. I downloaded all installed all the drivers put the only thing that doesn’t work is the FN key + Space bar to get the fan modes Eco, Balanced and turbo can you send me the drivers for that.
Model Number XCorBXIY1H241292840
Hi, what program did you use to clone the original SSD? How long did it take? Did you use a USB-C adapter to do it?
I used EaseUS Todo Backup Home and a UGREEN M.2 NVMe SSD Enclosure. I’m not sure maybe 2 hours because I just left it to run and chose the shut-down when finished option.
Hello, are you changing the hard drive for a larger one or because the hard drive has faults?
Nope I just need more space, I upgrade to a WD BLACK SN770 1TB NVMe M.2 SSD
Check if the file “powercontrol.exe” is running in task manager - startup app.
The executable can be found in this path:
C:\Program Files\powercontrol.exe
No nothing, I’m guessing that is that cause of the issue any idea of where to download it
Try searching for “powercontrol” here on the forum. There should be a thread about this issue.
Still not working, do you know which driver it is? I’ve tried them all.
