corebooX i5 12450h left speaker (solved)
S/n JCorBXIY2H240800854
Left speaker doesn’t work out of the box.
Tried to on different OS’s (win10+drives from chuwi website and ubuntu). Result is the same.
3.5 mm jack works fine.
Any solutions?
If you already checked that is not software related, the solution is to repair right?
Nope, there is another one related topic with exact the same issue
CoreBook X cwi570 drivers problem for BT TWS and speakers from laptop - Laptops / CoreBook X - CHUWI | Official Forum
TS solved it with another driver install (notice that driver published 27.03.2012) which is not listed in archive you offer.
So, I assume that you might be familiar with that issue and could provide/working on software related solution.
So, the problem solved with @timofey solution.
Find and install Realtek R2.83 driver. This driver is not provided by chuwi by default.
Note, that you have to disable all audio devices via device manager before installation.
@ChuwiESnotactive please, close thread and mark as solved.
