CWI515 WiFi driver broken
I have a Chuwi Hi10 CWI515,
Serial: Q64G42151102XXX
BIOS: C106_B101UAN.608 x64
I had problems installing WiFi for:
  • Broadcom 802.11n Wireless SDIO Adapter
    vid_02d0&pid_a9a6 (error: cannot start)
  • bcmfn2
    Same ID, (error: waiting for previous device)
I have tried your drivers offered at
Didnt work (despite the hint to copy 43430r0nvram.TXT). Internet wisdom advised to remove the .txt extension - also didnt work. On a previous fresh install I had also tried numerous drivers from Windows Update catalog but that didnt help either (and I did remove any drivers, always).
How do I fix the WLAN?
PS: I must add that it actually never worked (I got it from a friend in that condition) and so far I used it with a WLAN USB stick. However, I want to resolve that problem but how???
Hello @Management I am still in need a working driver for WLAN…
Has this device dropped out of your support? If so, then please say so…
If anybody else has an up-to-date windows and working WLAN, please just drop a line here :slight_smile:
hola, tengo el mismo problema que tu, alguna sugerencia?
try this drivers: http://www.mediafire.com/file/4vx2jwnw4sok3ji/Hi10_X64_All_Driver.rar/file
Well, why am I not surprised that also didn’t work? :frowning: I did put a lot of effort and research and time into that, alas it still doesn’t work. Done here…
For the record:
NOT SOLVED - if you have the same problem CONSIDER IT BROKEN FOR GOOD!
In the retrospective I can only advise against buying CHUWI hardware - I have a really bad impression of chuwi now and will, of course, veto any such purchase in my circle fo friends and family.
