Or is there anything i need to do before using it? Download a drive or update or something… Tnks
Check the serial number of your device. If there is something like this, it means that it is a new version that supports H6
Are there any other differences between old and new version besides HiPen H6 support?
So if it has : “hi10x Q128G20012613”, it wont work at all?
Yisrael Silverberg
+972 508756657
בתאריך שבת, 16 במאי 2020, 6:42, מאת Management via CHUWI | Official Forum <chuwi@discoursemail.com>:
NO, you should use H3.
That sucks. I just bought my hi10x last month and doesn’t support the new pen?!
Will/could there be a driver to download to make it work in the future?
It won’t.
What is new about the new version? Old Hardware vs new Hardware.
Can you list the changes?
Thank you
The only difference is the stylus
I bought a H3 but I discovered my Hi10x is new version that does not support H3. If you want the H3 pen which supposed to work for your older Hi10x, I can exchange my H3 with your H6. Let me know if you are interested.
