Hi, Can I receive the complete drivers and istructions t install it for Tablet Chuwi Hi10x HiPadXD128G210603423?
For the operating system windows 11 can I download ISO from Microsoft site? or other way?
You can go to the Chuwi website, support, downloads.
The serial number is 19 digits long.
Are you sure the serial number has 20 digits ?
I told you about it in my previous post
My serial is composed 19 characters and number Hi10XD128G210603423 it’s exact.
Hi, I’ve tried entering the 19-digit serial number several times, but nothing happens. I’m sure Chuwi won’t let me download anything. They’ve closed the download section.
Some downloads are not online.
A moderator provides the download links.
Chuwi uses almost always Intell drivers, go to Intel and download the Wifi driver. When you have internet you can download Snappy and run it, it will find all drivers for my Freebooks and Corebooks, I think it will work for your Hi 10 to.
Hi George1, thanks for your response. I wish to ask you if I can use ISO downloaded from microsoft site to reinstall windows 11 on my Chuwi tablet. Thanks!!!
Yes, no problem.
ok, thanks George!!
Hi, also can I download before Snappy, in a usb stick, and after use it offline?
Download your windows, download the driver for Wifi from intel. After that install everything and ten download Snappy and run. No install for Snappy.
Good luck
