I bought this tablet to play streaming, unfortunately I encounter this big problem with wifi when I activate bluetooth, I attach two videos
chuwi tablet hippad max
snap dragon 680
android 12
can i solve?
snap dragon 680
android 12
can i solve?
Hey!
I have a different problem with wifi… The tablet don’t identifi the 5ghz freq.
I’ll try turn off bluetooth to verify if the same thing happens.
there are so many problems with bluetooth, for example the tablet recognizes and enables aPtx when you connect a compatible device but the audio does not work and for example the videos on youtube go at 1 frames per second, disabling aptx and reverting the audio to sbc it works properly
