Feature Request: Add Battery Charging Limit Option to Minibook X N150
Dear Chuwi Team,
I am writing to request the addition of a battery charging limit feature to the Minibook X N150. Currently, the device lacks this functionality, which can negatively impact the battery’s lifespan when the charger is constantly connected.
Many other manufacturers offer this feature, either through BIOS settings or dedicated software. This allows users to limit the maximum charge level, typically to 80% or 90%, thereby preventing battery degradation from prolonged full charge cycles.
Implementing this feature would greatly enhance the user experience and prolong the battery’s health, especially for users who frequently use the device while connected to a power source.
I believe this is a crucial feature that would significantly improve the Minibook X N150’s longevity and overall value. I hope you will consider adding this functionality in a future BIOS or software update.
Thank you for your time and consideration.
I passed it to Tech. Thanks so much for the idea
I’m also very interested.
Battery care, by setting a charging limit/threshold, is an important feature.
Hope for support in linux too.
Thank you
