Suggestion To Add 'Battery Charging Limit Mode' Function In BIOS (MiniBook X N100)
Hello ^^
I Am a Korean User Using Chuwi MiniBook X (N100 CPU) Laptop PC.
I Bought Chuwi MiniBook X (N100 CPU) Laptop PC a Week Ago
I Am Uncomfortable Because There Is No Battery Charging Mode Function While Using It T_T
Also, I Would Like To See a ‘Battery Charging Limit Mode’ Function Added To Prevent Battery Overcharging Or Battery Swelling Issues.
Other Brand PCs Have Battery Charging Limit Mode Function
So I Hope The Battery Charging Limit Mode Function Is Added In BIOS
If You Select ‘Battery Charging Limit Mode’ In The BIOS Menu, You Can Set It As Follows:
  1. Disable
  2. 40% Charge Limit
  3. 60% Charge Limit
  4. 80% Charge Limit
You Can Choose
To Explain It Simply, It Is As Follows:
  1. Disable → Disable Battery Charge Limiting Feature
  2. 40% Charge Limit → This Means Charging The Battery To 40% And Charging Is Limited After That.
  3. 60% Charge Limit → This Means Charging The Battery To 60% And Charging Is Limited After That.
  4. 80% Charge Limit → This Means Charging The Battery To 80% And Charging Is Limited After That.
I Think MiniBook X N100 Users Will Really Like The Addition Of The ‘Battery Charging Limit Mode’ Feature. >_<!
Thank You!
I heard it and sent it to the department to see if that could be done
Thank You So Much For Your Reply! ^^
My MiniBook X N100 BIOS Version Is DNN20 V2.22
BIOS Version : DNN20 V2.22
EC Version : 0.18
I Would Like To See a Battery Charge Limiting Feature Added To The BIOS. I Am Very Excited. >_<!
Do you have any news about it? Thanks
