bat
1
Suite du sujet Garantie+Descriptifs :
je voudrais acheté sur eu.chuwi.com le modèle gemibook plus en 16gb mais la caractéristique apparait comme :
GemiBook Plus 15.6 inch | Intel 12th Alder-N N100
Caractéristiques
Nom du produit GemiBook XPro
Est-ce normal ?
No, its not normal. Sorry
We just modified it.
It is GemiBook PLus.Not GemiBook Xpro.
bat
3
can i’ve :
Complete your purchase before they’re gone, and don’t forget
– use code ACN-EU-139A014-16 at checkout for 18% off your order.
Or more ; please.
Thanks a lot for more…
Sorry, i do not understand what do you mean. The discount code does not work?
bat
5
Yes it don’t work !
----- Mail original -----
i send you another one by PM . That one you sent is expired.
