Hello, I just bought this laptop (Gemibook Plus N100 16GB/512Gb) and it comes with Windows 11 home.
I was wondering whether I can install Windows 11 pro or Windows 10 pro. I prefer those versions better as they are more complete than the “home version”.
Is it worth it so I do not get problems with the drivers after installing a different windows version? Will everything work? Will it be as smooth as Windows 11 home?
I have backed up all the drivers and I am thinking of cloning the image of the SSD so if something wrong happens, .. I can go back to where I was.
Another question:
Is it possible to change its battery to a bigger capacity? I can tell that the battery does not last very long, almost 3 hours, and for a day out at work I wish it could last at least 5 or 6 hours.
Thanks in advance. ![]()
