Gemibook plus N100 CW1620 Audio drivers
I’m having issues with getting the speakers working on the device, just purchased from Newegg this week. I’ve tried the drivers on the support page but it doesnt seem to have done anything. The 3.5mm jack works fine but built in speakers are not outputing anything. The SN is HGeBPLIY1H240907621
When you buy a device and it doesn’t work as it should the first time you use it, there’s only one solution: return it.
The hardware is fine, speakers work when booted into a linux usb live environment. issue is with the Windows install/drivers. Returning would cost a lot in shipping and would make no sense.
