I recently purchased a GemiBook Plus. I just want the drivers to install a fresh OS.
I’ve attempted to get the drivers from the support page but I’m getting “Database Working Un-normal now, Please contact local retails and distributor for Service”.
I’ve also tried sending them a support request though the page. But It’s been a week and no response.
Anyone have any info or alternate source for the drivers?
Give us your exact model and the Serial number and i willl give them to you.
CHUWI GemiBook Plus, Type: CWI602, JGeBPLIY1H231204220
As people here recommend. Better you use double driver app (you download from internet) to make a backup of all your drivers. I send you here, but better you install first the ones you collect from double driver.
if they are not complete then install these ones.
I admit I was skeptical at first. The file extracted to a folder for “GemiBook XPro”, not the Plus. But all the drivers worked with only one exception. I was not able to get the “Intel High Definition Audio” device to work.
i will ask tomorrow for the specific audio one.
prueba este
That worked! Thanks for all your help. This laptop is the first Chuwi product I’ve purchased, now that this is solved, I can honestly say I have no regrets.
thank you so much, its good to hear sometimes good opinions as in the forum obviouslly people come here because they have problems
I appreciate it.
how to install this driver
check if this is ok for you.
I have also had a problem with the audio on my Chuwi GemiBook Pro with Intel N5100. Initially I kept loosing wifi connection after an update. (Wifi adapter not recognized). So I decided to reinstall Windows 11 and that solved the problem. But then I got no audio (unknown device in Device Manager and the touchpad was not working either.
I followed all the standard procedures and even tried Driverbooster, which resolved a lot, but still no audio. After some research I discovered the audio Chip set is from Everest Semiconductor and went to the following link
https://www.catalog.update.microsoft.com/Search.aspx?q=everest
I downloaded the latest 3 audio drivers from Everest (Everest Semiconductor Co - AudioProcessingObject - 2.0.9.5)
In the device manager I manually updated the Unknown Device tag and it actually started updating!
After a reboot the audio was back and fully operational. I hope this information is useful.
thank you so much
