W11 Drivers for GemiBook Plus N100 TYPE: CW1620
I am looking to find the drivers for the Sound card and some other device that displays in device manager as
“on PCI Express Root Complex”
with instance path
“ACPI\INT3472\0”
Give me your serial number
serial number
JGeBPLCY4H240100944
GemiBook Plus TYPE: CW1620
Try to install these
Hello, thanks for the quick reply AND it’s working!!!
I first unpacked, then I installed the included SetupME file. I restarted my laptop.
I checked device manager. Still the same, then I tried to update the missing driver pointing to the driver directory in the files. But also, to no avail.
Then I remembered I must uninstall the old driver first. And after that in the top of device manager add drivers and guess what " IT WORKS ". Thank you very much :wink: regards from a retired Belgian IT man living in the Philippines.
As they say here: " GOD BLESS "
Im glad¡ that i helped with our issues¡ Is good to receive sometimes good opinions, as this forum is mainly about repair and issues, so its good to hear it.
Thanks so much
LGeBPLCY1H230802437
no audio and touchpad gemi book plus n100 cw1620
JGeBPLCY4H241002033
What have you done to make that happen ?
