Hello
I have 2 versions of GeminiBook Pro 14
The older one i bought one year ago 12GB 256GB J4125 In this one the fan keeps spining all time.
The new one 8GB 256GB N5100 , i can not ear the fan working. Even installing windows 11 when pc gets hot. Is it supose not to work? can i test the fan anyway?
Which one is correct?
I have the same issue, it’s getting really hot but I’ve never heard a single sound. Maybe the fan isn’t there or broken? If I can’t find the solution, I guess I need to return mine.
After searching about it. I found that the N5100 CPU can be passively cooled. So chuwi removed the fan in this model. Can someone from chuwi confirm it?
Someone did a tear down of the Larkbook X, which also has the N5100. There is no fan on that laptop. I assume it’s the same for the Gemibook Pro.
