I have tried to hard reset my chuwi hipad X tablet android 11 but It doesn’t work and secondly I tried every video but nothing worked every time I try to hard reset it it takes me to a Chinese menu
I don’t have a tablet.
You usually do a factory reset from the settings.
If it shows you a menu in Chinese, You can use Google Translate on your phone; just activate the camera.
I have done that there is no wipe data/factory reset or something similar
You can contact support
I have tried everything I even contact the aftersale services
What happens when you go into settings, system, recovery options, return to factory state ?
I have forgotten my pin so I can’t access settings
il faut remplacer le ssd conrompu
Send your serial number so i can send all the files to reinstall
Here is my serial number S/N:YHipaAEP40231002706
Hello Tumza, looking at that serial number , your device is from South Africa. They come with a locked recovery menu and it turns off if you hold volume down and brings up a test mode if you press volume up. Here is how to solve it;
You need to download and install All in one Microsoft Runtimes first.
You need SPD Research Tool
Unisoc driver
The firmware pac file for your phone (PAC) file is this one.
After u load packet, hold volume down and connect cable then release it when download starts. It takes around 4 minutes to complete. Let me know if you get stuck.
Thanks I will try it
i have flased mine with this pac but now its not touching serial number:YHipaAEP40231029492
Need official .pac firmware for HiPad X — Unisoc sharkL5pro platform, Android 11.
Serial: YHipaAEP40231002849
Distributor: Rizzen / Rugged SA (South Africa)
Build info: BB Chip HiPadX, Platform sharkL5pro_pub, MOCORTM_20A_W22.08.6_Debug, build Oct 11 2023, HW version 02-26-2022
Locked out (forgot pattern) — need this to factory reset via SPD Research Download tool.
