hi im after drivers fir wifi and chipset not through the intel program the problem i have is
PCI Data Acquisition and Signal Processing Controller
after starting laptop i have to re-start to connect to wifi any help would be great but the intel drivers dont help thank you
Can you explain what process you have done before reaching this state? or if it was spontaneous. It would help to find a solution to be able to know it since to find solutions it is necessary to know the reasons
Yes the problem below
Is a problem that needs the wifi and network drivers re installing and also the chipset drivers this problem is after a windows update and microsofts advice is to install the drivers listed thank you
after a windows update this is a known problem and needs the network drivers wifi drivers and chip set drivers re installed
you can go to most pc makers site and download the drivers but not with Chuwi
a link to the correct drivers would sort this problem out
you just have to wait for me to answer
