Herobox - No HDMI sound option in Linux
Hi, I have installed Arch linux on my herobox. However, I am not given an option to select HDMI as the sound output. By default all the disributions of linux I tried did not work properly with the sound card and only offered a “dummy output” unless I intalled the sof-firmware package. This also happens with Mint (Ubuntu).
Is there any way to get HDMI audio output? Did you do anything special to the packged Ubuntu to address this?
Thanks.
Hi, I found a fix that worked for me. Putting it here for other people to use.
echo “options snd-hda-intel dmic_detect=0” | sudo tee -a /etc/modprobe.d/alsa-base.conf
echo “blacklist snd_soc_skl” | sudo tee -a /etc/modprobe.d/blacklist.conf
Then reboot. HDMI was then an option and works fine. I read that this was a linux kernel regression.
Thanks.
