After the initial setup of Windows 11, and restart pc.
The pc can never boot into windows.
always stuck @ Bios Chuwi screen.
Model : HeroBox
CPU: Intel Celeron N5100
RAM: 8GB
SSD: 256GB
Serial
ZHeroBCZ2H230301393
First, remove the storage and see if it boot into BIOS, if it does, its a storage or OS issue, if it doesn’t boot into BIOS, you must try to reset the BIOS by removing the battery.
If its an OS issue, try with Live Linux or reinstall Windows 10.
If after all these solutions it does not boot into BIOS, throw it to the garbage bin.
The BIOS or some hardware (other than the SSD) is fucked and cannot be fixed.
