I was thinking to add a: [1TB SSD 3D NAND A55 SLC Cache Performance Boost SATA III 2.5" 7mm (0.28") Internal Solid State Drive (SP001TBSS3A55S25)] to the Herobox.
Product Link: https://www.amazon.com/gp/product/B07B4G19X3/ref=ox_sc_act_title_1?smid=A25SITGFW0OQJA&psc=1
I see that certain HDD cards can be plugged into the bottom of the computer (plug and play), can the above SSD card work (and fit) into that same area at the bottom of the herobox? If not, do you have a 1 TB SSD recommendation that will fit and work correctly, where the HDD expansion drive would plug in?
