Hi Pad Max reboot loop Freezing
Something happened, the screen is not loading correctly. The rom was incorrect.
EDIT:
This is the ROM that worked for me. Chuwi Hipad Max Snapdragon 680.
https://www.needrom.com/download/chuwi-hipad-max/
The first one.
JHIpdMKK10220801708
I have similar problem…after i put my pin it will just restart automatically …
Im not tech savvy…so i hope there will be a system update…
thank you for updating. Is weird because i gave you the correct Rom for your devide following the SN . But anyway is good you solved
@Hipad137 Your Serial number has the same software i posted above. You can download and install.
My terminal has been bootlooping for 2 days as well, but I solved the problem with the following method.
However, it is assumed that the device can be booted in safe mode and operated without problems.
Start in safe mode and go to settings to delete and disable the cache of Google Play services.
Once disabled, reboot and enable Google Play services from the settings.
I hope this procedure helps as it now works correctly.
Update for my case…
It got solve by Clearing the Cache of “Google Play Services” and unchecked the “Remove Permissions and Free Up Space”
Just quickly toggle for the setting gear icon above the notification panel then quickly search the Google play Services
hello. I always have problems with my hipad max. I found it locked on logo screen many times and had to hard reset it. Today after i turned it on, it told me data was corrupted and had to hard reset it agai. Since i get bored of this ridicolous software problem, can you tell me how to solve it? The serial number is JHpdMKK20230106167. I bought it on amazon on the 18 september 2023.
I just got informed that more people have reported this problem also to my other colleagues of Hi Max Pad rebooting i would appreciate you guys sending me a video, you can upload in the forum, less than 10mg.So we can pass it to tech.And they can try to make a patch or something
@Hipad137 @niko8 @shun841 @BtheDemon @Kbar8371 @Paulc
next time i will have to hard reset it, i will take a video. But the problem is real pls give us a solution now.
The solution must be done by tech, we already passed this. So they are working on it. But i need more proofs to be able to explain better, that is why i suggested the videos
The serial number for my Hipad Max is is 28f7d39f
JHipdMKK20230408149 this is my serial number and have the same problem, bootloop freezing @ChuwiSpainSupport what do I have to do ?
My HiPad Max Snapdragon680 suddenly is stuck in an endless reboot loop. It started to reboot automatically yesterday. After every start it immediately reboots again. I tried to switch it off completely but the buttons are not reacting and the touch screen also does not work.
This is a video of the loop: https://youtu.be/MfD_nRxaNG0
I can’t find the serial number because I can’t log into the device and it’s also not on the invoice.
hola Maria Isabel
buen dia
Mi nombre es Jorge y quiero dejarte saber que tengo problemas desde hace dos dias con mi tableta chuwi hipadmx se reinicia constantemente sin parar.
Estaba funcionando perfectamente un dia y al siguiente en la mañana solo se apaga y enciende sin parar
Tengo un video de lo que esta pasando
dime si tienes una solucion? por favor!
la compre el pasado julio 2023
A Y U D A P O R F A V O R !!!
Hi
I have the same issue with my hipad max since 2 days ago.
all the information found it doesn’t work .
I owns from my Hipad max since July 2023
This fix the bootloop for my case…
Right after opening scroll down the notification panel and press the gear icon…go to APPS…
Look for Google Play Services…and clear cache…unchecked the remove permissions…
Perform all this in less than 7-10 seconds…
Hope this help someone…
IF What @Hipad137 user said (by the way thank you) does not fix your problem please reinstall the sistem. Tech already knows about this and they are working on it.
On the meantime please everybody reinstall the system according to your serial numbers,.
They are in batch, search for yours here:
1-.SOFTWARE
BATCH 1:
JHipdMKK10220800001-JHipdMKK10220803000
JHipdMKK10220803001-JHipdMKK10220804600
BATCH 1 Install:
BATCH 2:
JHipdMKK20221100001-JHipdMKK20221103000
JHipdMKK20221103001-JHipdMKK20221104500
|JHipdMKK20221104501-JHipdMKK20221105000
BATCH 2 Install:
BATCH 3:
JHipdMKK20230100001-JHipdMKK20230103000
JHipdMKK20230103001-JHipdMKK20230105000
BATCH 3 Install:
try this:
If after install the previous one your touch does not work try this one
BATCH 4
JHipdMKK20230105001-JHipdMKK20230106600
JHipdMKK20230106601-JHipdMKK20230108100
JHipdMKK20230400001-JHipdMKK20230403000
JHipdMKK20230403001-JHipdMKK20230406000
JHipdMKK20230406001-JHipdMKK20230410000
BATCH 4 Install:
2-TOOLS
*******NOW DOWNLOAD THE APP TO FLASH.
YOU NEED TO INSTALL THIS BEFORE INSTALLING THE FLASH TOOL
FLASH TOOL:
HOW TO FLASH
@ChuwiSpainSupport Hi, I have the same problem as @jaaronpm. The table does not go from the active state and restarts after 5 seconds
Number series:JHipadMKK10220800877
I can’t install anything, the tablet is rebooting every 10 seconds and is not responding to any button press or screen touch. I installed all the necessary tools on my pc but the app does not see the device, it’s rebooting to fast.
The only thing working for me would be a complete replacement of the device.
En modo seguro se mantiene encendida
