Wow, we got almost same issue 2 days ago, April 14. The only difference is - we can observe lock screen as long as we want, probably because of pin code. But as soon as pin code entered, it freezes in 2-3 sec and then reboots in 5 sec by a watchdog.
JHipdMKK20230408661
@jaaronpm en la chuwi hipad max estando encendida la tabled, mantienes precionas el icono de apagar 3 segundos te saldrá la leyenda entrar en modo seguro
@xkip entra en modo seguro funcionará normalmente,
Entras en ajustes buscas servios de Google ihnabilita la aplicacion completa quita los permisos de 24 horas actualicen y contenido munltimedia
Te funcionará hasta que se solucione esto
I have asked tech to record me a video on how to flash properly, i hope i can have it today
He pedido a Tech que me haga un video de como flashear, espero tenerlo hoy
This started happening to me the morning of April 12, 2024 Central Time. Was working fine the previous day. I can force reboot and is fine until I enter the PIN. It then waits about 3-5 seconds and reboots. What are so many HiPad Max tablets having the same issue all at once? Was some change rolled out that would impact them all?
Used advice from Gerardo1 and applied to “Google Play Services” (Thank you Gerardo1) @xkip enter safe mode will work normally,
Go into settings, search for Google services, disable the entire application, remove 24-hour permissions, update and multimedia content
It will work for you until this is resolved.
To get into Safe Mode I pressed the Power Key and then kept my finger on the “Power off” option that pops up on the screen for a few seconds and it asked me if I wanted to reboot into safe mode. I did all this without entering my PIN.
I can again use my HiPad Max now but it keeps bugging me to Enable “Google Play Services” I will keep that off until I see some sort of solution here in this forum topic.
April the 12th? Interesting. Mine also started on that morning, I first discovered it around 9am GMT. Again my Hipad was working fine the previous night. Does make you think that, something like an update has caused this.
Sadly, in my case it is kid’s device and it is locked by parental control, I think that’s the reason why I don’t have “Safe Mode” button in power menu.
