HI, I HAVE BROKEN THE LCD SCREEN OF MY Hi10 Pro TABLET with Serial No:HQ64G42170701244 AND I NEED TO REPLACE IT, BUT CAN’T FIND WHICH REPLACEMENT TO GET.
I CAN I GET THE CW1529 (WITH DIFFERENT SERIAL NUMBERS) BUT WOULD IT FIT TO MY TABLET?
COULD YOU PLEASE HELP?
THANKS
Hi10 Pro has different touch models, so you should open the tablet and see the type of touch you have, just open it since the difference is in the flex that connects to the board, which may or may not have microchips. Once you know the model it will be easy to get it on Aliexpress
Thank you. I will open it and find out.
