Hi
The touchscreen of my Hi10 X Pro stopped working after restarting.
Is there a solution?
My serial number is YH10XpAB30231109125
Hi
wait you use windows or android? android is very very problem windows drives is bugget reinstall drivers
I use Android ![]()
bro… is very problem… reinstal?
This video is in Spanish but is easy to understand.
wait i can get iso for my android
only android for hi10pro HI10 HQ64G42180105271 or CWI529
We cannot separate them, they are together Android and WIndows ![]()
okay
I follow the tutorial and did the hard reset but the touchscreen still doesn´t work ![]()
Any other suggestions?
yes install custom rom
yes sell it
yes this (idk i dont read) Chuwi CWI529 Touch screen dont work!?
yes giveme
yes smash this
and more
it may be broken, then you would need to send to repair.
