Hi10 X1 N150 Drivers
I am trying to install Windows 11 using Ventoy and I am getting stuck on the screen that says “Install driver to show hardware”. I can’t find the drivers on the Chuwi website and there is very little documentation for this device. Please share all BIOS updates, firmware and drivers for the device.
WHy would you want to reinstall Windows on a tablet that is so new?
YOu send to send the serial number otherwise i cat send the links
I don’t trust any pre-installation and need the drivers for a complete reinstallation - the driver linked on the support page (zip file) is defective
Hola Maria, were you able to help this user source the drivers for his Hi10 X1 N150 to reinstall Windows cleanly? I am also interested in the same please provide us with the driver link.
Hello My friend were you able to resolve your situation with chuwi support on the drivers for Hi10 X1 N150?
Hi10 X1 N150 드라이버
This is a driver extracted directly.
Send the serial number otherwise i cannot give the link
No I was unable to get windows to reinstall, not really an issue as I prefer Linux. I would not trust the windows install that Chuwi provides by default as it does not require a proper windows setup. I would recommend Fedora with KDE as my distro of choice for this device as it is the best experience I have found so far.
I think Chuwi should provide an install guide for windows 11 as the fact they expect you to never need to reinstall windows is ridiculous.
If anyone has successfully installed windows I would be very interested in how they managed it.
