Hi, I am getting this error when I turn on the tablet. It keeps on restarting
Blockquote
INFO: your device is corrupt, It can’t be trusted and may not work properly!
INFO: Press power button to continue.
Blockquote
Try to reinstall the system:
Firmaware
Android Tutorial:
Tool:
Already tried reinstalling it using the file you provided but It did not fix it.
I already reinstalled more than 5 times using different usb cable and downloaded the firmware file several times to make sure it’s not corrupted.
It keeps on restarting and I got this new message:
Did you try with this tool?
Yes, I used the tool you provided. See screenshot below when it was completed. But it still did not fix the problem
@manonegra222 why do you think it would be?if the software is correct and follow instructions
My screen stock og chuwi Android,
Serial number: JH10XpAB60241105471
