Hi10 XPro You device is corrupt/
It can’t be trusted and may not work properly
Press power button to contime
Or, device will power off in 5 sec.
Serial JH10XpAB50240302472
Where did you buy it (Aliexpress)
When did you buy it (12.08.2024)
As you just bought it and its under the 14 days warranty. Please contact Aliexpress so they will replace you with a new one. Its better that try to solve the problem.
