Thank you
私もパスキーが不明となり、リセットしたいです。出荷前状態にしたいです
シリアル
YH10XpAB30231107853
Hello! I also need the firmware file so I can factory reset my chuwi hi10x pro. Pls reply asap.
SN: JH10XPAB50240106123
i sent them in the post you created
Chuwi Hi10 XPro.
I forgot my pattern key and can’t remember it. Please help.
S/N: YH10XpAB10230504760
JH10XpAB50240303872
JH10XpAB50240303872
I need the boot image for my chuwi HI10 XPro please where can I get it?
send the serial number
I need to factory reset as well…mine keeps randomly restarting every few minutes. S/N: FE80B4B5E4475D476337
Hi. I need to factory reset to my CHUWI Hi10 XPRO. Somebody can help ?
It`s my serial number: YH10XpAB30231001904
Firmware:
Tutorial:
App for reinstall
that is not the serial number. Check in the box or the Sim carm slot, in the corner.
Hello! I also need the firmware file so I can factory reset my chuwi hi10x pro. S.N JH10XpAB50240301738
Hello! I also need the firmware file so I can factory reset my chuwi hi10x pro / my serial nunber is YH10XpaAB30231000956
Firmware:
Tutorial:
App for reinstall
Thank you. Everything is ok.
