Hi10 Xpro how to recovery mode
Boa tarde, perdi o PIN do meu tablet alguém me consegue ajudar?
utorial:
App for reinstall
Bom dia, obrigado pelos ficheiros, instalei o programa mas não conecta com o tablet, não instala o software
Check the cable sometimes that is the problem, it must read the tablet. MAybe you are doing something wrong did you follow the instructions as in the video?
Hello, can you give me the link from the software of this serial number: YH10XpAB30231108549.
I hope if you can help me, thanks a lot, have a nice week.
Здравствуйте как мне сделать сброс? У него нет RECOVERY mode?
серийный номер YH10XpAB20230700463.
utorial:
Please, give me FW
S/N: YH10XpAB30231102935
Could I get the file for Serial ZHipXpEY00231206320. Thanks in advance.
Same problem here:
Serial Number: JH10XpaB60241104745
Thank you.
YH10XpAB20230703883, I need help too. Thank you
Hello good day, i have issue with the Chuwi H10x Pro, when I power On the tablet, I cannot Log in, the virtual keyboard disappeared. I can’t see the keypad. I cannot input my password, Can You Advise me what to do, thx
I needed an android 15, my serial number is JH10XpAB6025050186
What version of Android do you have ?
What happens when you update ?
I can’t remember the PIN for my Chuwi Hi10 Xpro tab. I can’t connect it to my pc to do a factory reset. Can you please help? SN: JH10XpAb60250501019
  • Serial #: JH10XpAB50240103298
  • Need to flash Hi10 xPro
  • Stuck in emergency mode.
  • Thank You
  • Thank You
