I have a non working tablet since receiving it in late November 2020.
I have tried to turn on my new tablet & all i get is a blue screen before I have used this tablet.
I have contacted Chuwi service & they have asked me to try to reinstall.
they sent me a link & i have downloaded the software & all drivers.
Have tried to follow the instructions sent (see below) but i just cannot get windows to reinstall.
For a start it appears to be working but after 10 hours of a black screen i gave up.
Does anyone have any ideas on how to reinstall windows?
Introduction to flashing (reinstall)windows System
Preparation tools: 16G or more memory U disk
Note: Make sure the battery power exceeds 50%. Or plug in the power brush
Format the USB flash drive with the NTFS format label named WINPE (if the WINPE system is not named, the USB flash drive will not be recognized) as shown below.
2. Unzip the downloaded package of the network disk, as shown below
Open the windows file package and copy the subfiles to the root directory of the U disk,
3. The method is to insert the USB flash drive into the computer. After turning off the computer, press the power button to turn it on. Press F7(or esc) at the same time, then select UEFI:Sandisk, and select partition 1 to select the USB flash drive to boot. The notebook will automatically install windows.
- When this interface appears, it shows that the machine is normal.,
After the installation is complete, it will automatically shut down, unplug the USB drive and reopen the laptop.
After booting for the first time, enter the test mode and double-click the cleanup on the desktop.
