Hi10Max N150 OS and Drivers Support Files
Serial Number: ZHiMaxHZ1H250501168
I have just bought Hi10Max N150 in Indonesia and I would like to create a backup of the OS and Drivers just in case I needed it later. This is my first Chuwi product and I’ve been reading up on the forum for more information.
I have a couple of questions:
  • the OS zip file contains 2 folders, Images and WinPE, how should I copy them to the flash drive, because the structure of the folders are different than the instruction document I found in this forum (the instruction only has 1 folder named Windows and the content needs to be copied into the root directory of the flash drive)
  • Does the Drivers zip file need to be applied when reinstalling Windows 11 from the OS zip file? Or are they already applied and only needed if we install vanilla Windows 11 from Microsoft?
Thank you :folded_hands: .
I never back up Windows.
You can search Google for how to back up Windows and how to back up drivers.
Tutorial on how to install Windows on a USB drive:
Tutorial on how to install drivers:
I need drivers for my Hi 10 Max N150 SN:ZHiMaxHZ1H250503058. The drivers from the site are in the wrong language and with no installation files.
