Hi
I have just received my hipad Max. Whenever I move it the screen automatically locks. This is very annoying as this is a mobile device so I should be able to move it.
How can I disable this locking when I move the tablet?
Paul
Do you use a cover / case ? Try it without.
Hi, I am using the official Chuwi case so it would be ridiculous if that causes the tablet to lock screen in use. Bought from the Chuwi shop on Amazon
Same result without case ?
If the cover is folded back fully over the camera then the screen locks, if it is double folded so only half covering the back then the screen doesn’t lock.
Fingers crossed this is ok.
