HiPad XPro T616 Android 12
S/N from SIM SLOT
ZHipXpEY00230312386
Ordered it from Amazon MX on the 19th of December 2024
The “bootloop” goes like this:
Tablet restarts → boots back up and everything works from 30 seconds to 2 minutes after I unlock it → restarts again.
If I leave it idle for about 30 minutes without unlocking it and then unlock it the tablet won’t restart again, but it will restart and go into the “bootloop” if I leave it charging, connect it to a pc for USB debugging, using it as a secondary monitor via USB or join a Discord voice call.
Why do I write it like “BootLoop”? The restarts aren’t constant and only happen if the conditions from above are met.
I assume this is a firmware issue so I’m looking to update it and see if it solves this
I could provide a video showcasing the issue since it can be recreated, if it helps
