HiPadMAX-680-ROW-2024-1127-U-V.1.9
Hi, My Hipad Max need New Firmware.
cound you give me new firmware on OTA?
current build number : HipadMAX-680-ROW-2022-1112-U-V.1.5
need build number : HiPadMAX-680-ROW-2024-1127-U-V.1.9
My serial Number : JHipdMKK20221103082
What happens when you update from the settings ?
When I check the wireless update from the settings screen, it says “Your phone is already up to date.”
possibly EOL: end of life
Thank you.
So what is the difference between the HiPadMAX-680-ROW-2024-1127-U-V.1.9 version and my HipadMAX-680-ROW-2022-1112-U-V.1.5?
If I had checked for the update earlier, would I have been able to apply it?
The moderator can tell you that.
It’s probably for another series of the same model.
Write to service@chuwi.com and tell them to give you this file HiPadMAX-680-ROW-NEW-2024-1125-U-V.2.0 is the update that corresponds to your serial number
Thank you :slight_smile:
I will write email to there.
I have the same model as you and the same problem with not getting the OTA upgrade. Did they send you the latest firmware yet? I have emailed and setup a query but no replies. Thanks
Yes, I received a reply and the latest firmware.
I’m still waiting for a reply, do you have a link to the firmware please? Thanks
try this, this is the file I received from support.
Thanks very much, I will try it out :grinning_face:
Has your device been restored?
Hi, yes your firmware seems to be working well. The support team did eventually sent it but you were faster haha, thanks again.
