Good afternoon. there is a huge problem with the ax201 wifi module, but it doesn’t wake up after hardware hybridization (it has hardware (software is disabled in windows), when you send the laptop to sleep, the power light starts blinking slowly and then it goes out, and you can turn it on only by pressing power button). after turning on there is no wifi, in the device manager there is a network card with a driver error. There is only one way to treat it - disconnecting the battery and completely resetting the system by power supply. After that, everything returns to normal. HOW TO DISABLE HARDWARE Hibernation??? Where is it in the BIOS?
I managed to solve the AX201 problem by disabling hibernation in the BIOS (didn’t need to detach battery or anything else).
Option is in BIOS under Advanced and then ACPI settings.
I changed this to Disabled and it worked right away!
PS: disabling and re-enabling “network stack” in BIOS as suggested by others did nothing for me.
