I explored different trouble shoot options from Advanced options.
4 of the options needs an administrator to sign in, namely,
Startup Repair
Command Prompt
Uninstall Updates
System Restore
But the PC won’t recognize me as an administrator . Tried to click on the statement below them:
Forgot your password or don’t see your account?
It won’t help me either. Because it will just tell me to restart and the result will just be the same:
Your PC did not start correctly
In Startup Settings I’m not sure what to choose. The options are:
Enable low-resolution
Enable debugging mode
Enable boot logging
Enable Safe Mode
Disable driver signature enforcement
Disabke early launch anti-malware protection
Disable automatic restart on system failure.
Same goes to UEFI Firmware Settings
Have you experienced this? Do you already have a solution for this?
