By default the Windows settings are only 50Hz, I want to set it to 60Hz but there is no choice. Serial number: ZMinBXHY4H240201634
There is another topic about this:
50 Hz is as designed. There is no bios update. It seems this is done for homologation purposes.
You might be able to increase the refresh rate with third party tool.
YMMV.
Just remember to keep your finger on f8 key to revert the refresh rate if it doesnt look right. I think I covered everything else in the topic above.
You guys were faster than me
i was going to post the same past thread .Thanks for the help
