Hi everyone:
I open this topic because I would like help with a problem that I have had for a long time and cannot solve.
I have a chuwi Hi10 Air tablet with serial number: Q64G19032028;
Which the problem is that every 10 minutes of use a blue screen appears, looking on the internet, the most common conclusion is that the flash has been damaged by a windows update, which I have tried to flash with files taken from the forums of this community with the famous WINPE pendrive, but even so it has not worked since it says when it reaches the diskpart screen that it does not find the necessary partition.
If anyone knows any solution or idea I would really appreciate it.
Thank you very much to all, greetings.
