Install win 10 home on herobook air 11.6
I installed linumint on my herobook air 11.6. Now I need to install windows 10 home again. I did the procedure and created the installation pendrive but during boot the pendrive, which was seen in bios, did not start the installation. What’s going wrong?
Send the serial number so i can send the files
How do I send you serial number?
What files would you send me?
I would send you Windows and the drivers. The serial number should be on the back side of the laptop
I can’t install any version of windows 10 and then it has to be 32 or 64 bit
Here is the serial numberHeroB AQ128G21082218
I’m waiting for the SOLUTION THANKS
This is the windows that came with it
Drivers
how about my herobook air HeroB AQ128G21084902 ? is it can be also ?
