I install android 9.0 rc2 on my chuwi hi10x by seperate partition.But it have big problem with “app keeps stopping”. I try to find slove this solution every way and try it not success, clear cash, reinstall ,update every apps from store etc. I try it every way. Not good luck for me. Pls recommed with me
I have tried to install Android x86 8, 9 but touchscreen, rotation or pen never worked.
I get the that error all the time with Android x86_9r2… Had more success with x86_8r5…had to do the rotate fix detailed in:
And also touch doesn’t work straight away for me (may 20 build chuwi) on 8r5…others don’t seem to report issues but for some reason it does work after letting it go to sleep and then waking it up…odd
