I’ve been annoyed with ghost touch for a long time about mY hipadx pro.
Is any solutions to fIx it?
Thabks in advance.
Have you tried to remove the screen protector? Or install any app to see if that can fix it?
Thanks for your quick comment.
I’ve already remove screen film three months ago but not Improved.
My ZHipXpEY00221204248.
My android verison is 12.
Today i installed the latest firmware which you anmounced on this site according to my version ZHipXpEY00221204248, but not especially inproved yet.
So i want to flash my android version from current 12 to 13 for which this proble might settled.
Q1. What your ROM version of android13 should I install to my ZHipXpEY00221204248?
Q2. Can I install it only by SPD Research Tool? Or any other tool needed?
Thank you for your strong support in advance.
We do not have Android 13 for your version. Just the new batches come with it.
IF you want you can install it, but we dont think its neccesary, and aslo battery will drain a lot.
You could send it to repair
