Keyboard Typing Wrong Letters
My laptop uBOOK DESKTOP-V4VAMUT (Product ID: 00356-02222-35651-AAOE) is typing wrong or different letter written on keyboard.
I tried to reset and change the languages, it always typing wronglt letter on keyboard.
I need your support to fix this issue.
Can you tell us a few keys you press and what you get on your screen?
When you click:
[ you get ’
  • you get <<
    \ You get. ~
    ; you get. ç
    '. You get /
    Shift ~ you get |
    Shift 1 you get !
    Shift ~ you get "
Saturday, 29 January 2022, 00:21PM +01:00 from L.yo via CHUWI | Official Forum chuwi@discoursemail.com:
Sometimes when keyboards start typing the wrong letters, it’s not only a language setting issue but also a matter of testing how responsive certain keys are. A useful way to check if the spacebar and other keys are functioning properly is to use online tools that measure keystroke speed and accuracy. One option is Try It Free to track how the spacebar responds during continuous pressing. It can highlight whether the problem is with hardware response or just system settings.
