The right side hinge of my lap book air is starting to loosen. I would like to tighten it up before it gets too bad…any tips?
Thanks Max
It looks very much like your picture
Mine is the lapbook air so the only plastic on it is along the hinge almost like it is a cover
I was wondering if you would be able to pry the plastic off to get at the screws anchoring the hinge?
You can fill this place with epoxy and fix the hinges for a day or two, many people repair this problem this way.
Thanks I’ll give it a go!
