Hi there, this morning my Lapbook SE won’t start. It is completely charged, when I press the startbutton on the keyboard, the blue light flashes after 5 sec (longer than normal) it stays on for 1,5 sec and it goes off again. Nothing happens!!
But (Also remove ssd) If you can’t even enter BIOS (i.e. press escape a couple of times directly after powering on) then the problem is very likely a hardware problem.
Try holding the power button down 14 seconds and then charging it for a good 6 hours. Then press the power button 4-5 seconds a blue status led should flash (1-2 of the 3 status LEDs on the right) and then the chuwi Logo if you’re lucky will appear.
