I recently bought a Larkbox Pro to use for astrophotography but I have problem with connection to my Cooled USB3.0 camera (QHY294C Pro). When I plug it, windows sees the camera in but the connection is not stable, In the device manager, the page is refreshing for every few seconds. I tried short usb3.0 cable (1 mt instead of 2) but it also didn’t work. Camera is working properly with my two laptops.
I also have another usb3.0 camera (ZWO ASI 290MC) which has smaller sensor and it is working properly with Larkbox.
I tried Baseus powered usb3.0 hub but nothing changed. I checked the USB hub with my laptop but the camera didn’t work with this configuration, too. It only works when I plug it to the laptop directly.
I assume larkbox usb 3.0 ports should work like my laptop ports but is there any difference? Do you have any suggestion to sopve this issue?
Thanks in advance.
Ahmet.
