My Larkbox Mini PC won’t power on. It is completely black.
Any idea?
Any idea?
Hello, I had the same problem on the first boot. I had to connect the mini PC through the HDMI port
do you mean you had to connect an HDMI cable with a screen on it to get it to work?
Regards Richard
Yes I assume that the Display port does not work at first startup only
same !
all of the sudden it stopped working
still completely dead.
is the LED on the power supply blinking? if so, it’s a problem with the power controller. I had the same problem.
My power supply has no led light. But I suspect that is wrong with power. How did you fix yours?
replacing the power controller in the service
