Where can we find the drivers for Larkbox X ?
From what I understand Chuwi does not provide driver downloads unless support sometimes grants them to you.
Good morning.
sorry for my english
I am owner of a CHUWI LarkBox X AMD Ryzen 7 3750H
I had windows 11 installed and I changed it for windows 10.
My problem is that it does not recognize the network adapter and other devices.
I installed different versions of windows 10 and even reinstall windows 11 but I still have the same problem.
I don’t know where the error comes from and I don’t know how to fix it.
I’ve tried different drive packages that I’ve found in the forum, I’ve tried to install them manually, with DSIM++ and other programs and I haven’t solved it.
Please someone can help me to solve this problem.
Thanks in advance
Finally I got the drivers
Wasting my time and no help from support, bad Chuwi very bad.
where did you get the drivers?
Hi, you can check this reddit post: https://www.reddit.com/r/larkbox_x/comments/xi8o58/chuwi_larkbox_x_review_the_important_things_you/
The drivers are easy to find, those in particular I think can be installed by downloading from amd it’s automatic setup tool, that will check the system and install gpu and chipset drivers.
