Good evening everyone. I have had a HeroBook since January, but the speakers have gone crazy for about a week. have discharges, the audio disappears, in short, a disaster. Is it possible to use Realteck drivers instead of those already mounted by Microsoft? Thanks (and sorry for my english, I’m Italian and I don’t speak / write well)
thank, Elisabetta
Non so se il tuo problema attuale sia motivato da un cambio di driver da parte di Windows.
Puoi provare a reinstallare quelli precedenti, scaricandoli da qui: https://www.mediafire.com/folder/4fyvzpdqd86mu/Driver
Manonegra222 and Amadeoo, thank you both.
After many trials, in the end I did a system restore and for the moment seems to work.
I save the links, if it happens again I change the drivers.
thank you both.
